Double threaded hilt for Modular Hilt System. Has 14 machined grooves. Both ends have female threads. Little under 1.5" OD with a overall length of 7".
You can select to have no switch hole or a Standard, Guarded, AV, or Recessed AV switch hole which will be machined 1.5" from the non grooved end. If you would like the hole in a different location then please order it without a switch hole and order the switch hole service instead so you can specify the location.
( based on 2
Love it
This was my first purchase and I love it. Great hilt. It has a good grip with or without O-rings.
Great Hilt
This hilt is amazingly comfortable to hold with or without O-rings. Milled grooves on the hilt hold the rings in place to add a nice touch. You might want to add an extension between the blade holder and hilt to give your LED wiring some extra space. I have the recessed AV switch hole and a short AV switch with accent LED ring. There is not a lot of room for wiring without the extension.
