Double threaded hilt for Modular Hilt System. Both ends are female threaded. Little under 1.5" OD with a overall length of 7".
You can select to have no switch hole or a Standard, Guarded, AV, or Recessed AV switch hole which will be machined 1.5" from one end. If you would like the hole in a different location then please order it without a switch hole and order the switch hole service instead so you can specify the location.
                                    ( based on 2
reviews                                    )
Plain Tube
Nicely machined and fits perfectly onto the other parts.
Solid Customization Hilt
Got this pieces a few days ago, and yes, it doesn't have anything on it, and is plain- but is perfect for customization and came undamaged and well-milled. Has lots of room for etching and design ect.
