Double threaded hilt for Modular Hilt System. Has 8 machined grooves. Both ends have female threads. Little under 1.5" OD with a overall length of 7".
You can select to have no switch hole or a Standard, Guarded, AV, or Recessed AV switch hole which will be machined 1.5" from the non grooved end. If you would like the hole in a different location then please order it without a switch hole and order the switch hole service instead so you can specify the location.
(3)
Average rating 9 out of 10
( based on 3
Very nice look, smaller than anticipated
The product arrived today and I was delighted to see that it looked so nice, however I believed that it would be longer, capable of a 2 hand grip, however the length is perfect for my planned project.
Great Quality!
Comparing this lightweight hilt and durable material to some other builders it feels great in hand.
Looks even better in the hand
This is what I picked for my very first saber body. It felt pretty secure in the hand, as is, but I added the black o-rings to it. When it's all assembled it doesn't look like a toy, it looks like a movie prop. Thanks, TCSS.
