Trim Ring 4
Designed to be locked in place between two MHS sections
Should not be used next to a blade holder as it will change the internal spacing.
Should not be used next to a pommel if using a speaker mount that is locked in place via the pommel.
May not fit powder coated parts without modification.
Perfect to add some detail
These are great. Fits perfectly so seams disappear.
