Trim Ring 3
Designed to be locked in place between two MHS sections
Should not be used next to a blade holder as it will change the internal spacing.
Should not be used next to a pommel if using a speaker mount that is locked in place via the pommel.
May not fit powder coated parts without modification.
(3)
( based on 3
DETAIL & FLAIR
If you haven't tried any one of these trim rings, you are truly missing out. They really make your saber have more of a detailed look. All of my future sabers will have at least one. Thank You TCSS.
Brilliant
These deceptively simple trim pieces can make an otherwise boring MHS hilt into something special. And they are a great way to disguise a seam between MHS parts. Adding color makes them even more versatile.
The little things make a big difference
This is Perfect. Just the thing i was looking for to complete my saber. Out of the new additions to the shop so far, this is one of my favorites
