Trim Ring 1
Designed to be locked in place between two MHS sections
Should not be used next to a blade holder as it will change the internal spacing.
Should not be used next to a pommel if using a speaker mount that is locked in place via the pommel.
May not fit powder coated parts without modification.
( based on 2
Great look!
Bought this to separate my 4 inch extension from the choke I bought. It pairs greatly with the pommel style 10 as it has the same shape as where the pommel connects. Definitely recommend!
details,details,details
just ordered my second set of trim rings and as usual I can't see why you would build a saber without them. they truly give your saber that extra detail.the hard part is deciding which ones to order.
