12" long Aluminum Sleeve material.
These no longer have a bright dipped finish to make etching much easier
Fits over most standard MHS parts
1.574" OD
1.458" ID
.058" wall thickness
1.574" OD
1.458" ID
(6)
( based on 6
great
Glad to see this finally back in stock.Great stuff
Perfect for sabers
This is perfect for any of your shroud needs!
Perfect
Well worth the time, money, and effort
Hot stuff...literally
This product blows sink tube clear out of the water. Its thicker, so if you are cutting with a hand tool like a dremmel, remember that patience is the way of the jedi. It takes longer but well worth the time for a more pronounced overlay/shroud design to a hilt. Oh, and wear gloves if you use a hand tool, the heat transfers quick...one hot item...literally :)
Pure awesomeness!
I love this stuff...makes sinktube look like tinfoil.
