MHS LS Chassis - Proffie
Price: $27.50
  • SKUMHSLSCHPR
MHS LS Chassis for Proffie sound board
The chassis is designed to be used with a wired 21700 battery and a 28mm speaker. You will need a 2 channel 2 Pin Chassis Connector for the removable speaker to work which can be purchased Here. You will need the long pins for it.
Be sure to install the board as shown or the speaker mount will hit the SD card.
This is for the chassis only and the sound module is not included
