MHS LS Chassis for Golden Harvest v3 sound board
The chassis is designed to be used with a wired 21700 battery and a 28mm speaker. You will need a 2 channel 2 Pin Chassis Connector for the removable speaker to work which can be purchased Here. You will need the long pins for it.
This is for the chassis only and the sound module is not included
