Drill and tap one hole for set screw, thumb screw, etc..
Please select thread size and location for hole.
This service is for drilling and tapping the hole only and does not include making a flat spot for the accent LED to sit against, etc..
(6)
( based on 6
Perfect Service
I ordered drill and taps for a retention screw and a covertec clip, and TCSS nailed the positioning. I'm extremely happy!
Perfect placement
I ordered holes for a blade retention screw and a covertec. The b.r. one was on one of many windows of an emitter and it aligned perfectly with the rear side of the hilt, behind the switch, using the style 1 choke. With the style 2 it turned to be a little on the left, but it can be fixed. The hole for the covertec was exactly where I indicated. Both are clean, not a scratch.
Incredible work!
Well worth the $$ to have the professional Drill & Tap done. The quality FAR exceeds anything I could hope to accomplish with my limited tools, and skill. (I have tried Drilling & Tapping on PVC, and it is incredibly easy to just be off "a touch". No such issues this way!) Tim was also able to do this, and several other services (box service, PLI cutout, etc) according to my supplied layout/instructions, over several parts, all aligned perfectly. ALL of Tim's work is of astounding quality!
Precise jobdone.
I was very specific with where I wanted my blade retention screw hole on my emitter and TCSS came through with perfect placement.
Good work
Did it for the standard covertec clip plus a few misc. Very happy
