C-cell Mag-Lite blade holder
As far as we know these will only work with the classic style Maglite
Designed to hold 1" blades. 10-32 blade retention hole included
Use to easily convert your Mag-Lite into a saber.
Designed to be used with a lens, lens holder, and colored filters.
You *should* be able to use this with any C-cell Mag-Lite.
There are some sources on the internet for colored LED's as well which would work best.
            (7)
                                    Average rating 9 out of 10
                                    ( based on 7
reviews                                    )
New Maglite C - buttonless doesn't fit
The quality of this is great, this isn't a slam. I've tried 2 of the new Maglite C (2C and 3C) and this part doesn't fit either, not even a little bit. It slips right over everything. I did notice there's no button on the newer lights, they all just twist to activate. Not sure if that's the difference or not. The D version of this fits like a glove in the Maglite D series.
Great Blade Holder
This blade holder is excellent in design and fit. One important thing to note is that if you are placing this aluminum part onto the steel body of a maglite, the threads will probably wear out with continuous hard dueling.
Good and Solid
These fittings are beautifully machined and have tight tolerances. They fit snugly with a 1" diameter blade and require only a set screw to hold the blade in. I used a knurled thumb screw and the look and fit is terrific. I cannot recommend these components highly enough. Great for a quick-assembly fencing saber!
C cell maglite
Works great with older C cell maglites. Does not fit newer LED c cell maglites. The new maglites are smaller.
The Perfect Way to Start
This is a great piece to start into the world of saber building. A spare Maglite and this BH and you are on your way.
