Heatsink module for 1" ID tubes with center hole
Price: $9.50
  • SKU1HS
.994" OD x .8" Long
This version has a center hole for Tri-Crees or Tri-Rebels if you want to run the wires down the center of the heatsink assuming the LED star has a center hole.
Average rating 10 out of 10 ( based on 2 reviews )
versitile!
Review by Darth Gary on 3/4/2019
This is a great LED holder/heat sink. It saves me a LOT of time when designing and building custom hilts. I have attached it via a 4-40 rod to the V2 chassis bulkheads to make a slide in/out chassis for hilts with a 1" ID. Very well made and works perfectly with a single or tri-cree LED.
Great for tight build
Review by Brian on 6/16/2018
I needed a holder and heatsink for a hilt I acquired with only 1" diameter for light and blade. This worked great and is beautifully machined.
