MHSv1 Style 1 Quick Connect Adapter
Provides a secure hold and easily disconnects with a simple twist.
1.9" unthreaded length
1.45" OD
1.45" OD
Very practical design
The coupler is well made, and I replaced a different coupler in a staff used for performance / stage combat. The part looks fantastic and the parallel threads make a solid connection. The staff looks better now which is making everyone happy. We've tested it in practice and haven't had any problems with it disconnecting in action. The coupler is tightened with a (standard) right hand twist, so tends to be tightened with just regular "make sure everything is tightened up" twists. Note this means to disconnect you need to grab the part itself else you will disconnect the saber. Nice looking, practical, well thought out part.
