MHS V1 screw switch ring + switch combo for 8-32 screw
Price: $10.40
  • SKUSTSR832
MHS single tactile switch ring - will allow the use of an 8-32 screw as the switch. Switch is included.
For mounting the switch inside a 1.25" ID MHS section via the switch ring/switch 26 hole service
Average rating 9 out of 10 ( based on 2 reviews )
Good but awkward.
Review by Chris on 9/16/2021
A very nice option to hide a switch behind a more in-universe looking part but there's a couple things to be aware of; firstly the threads are very tight making it easy to cross-thread the soft plastic if you're not careful, secondly the tolerances for the screw position are very fine; slightly too close and the switch will be held closed, slightly too far away and it will engage but will need to be pulled back for the next press, but get it just right and it will cycle perfectly just tapping the screw.
Awesome!
Review by Zak on 9/22/2020
This is a super good product! Easy to assemble and use, I used it to fit switches into my DM1 kit, and this works phenomenally. I don't know anyone else that has a switch set up like this that isn't built into a chassis so this is a great thing to have. It also fits tactile switches with taller buttons if you need that kind of thing
