MHS Flex
Price: $229.97
  • SKUMHSGRFLX
Glass Eye
MHS Graflex Empty Hilt Kit. A hilt inspired by one of the most iconic Sabers in the Galaxy.
  • 1" Blade Emitter includes blade retention holes and screws. 5" of Blade depth.
  • Working replica graflex clamp with "Graflex" stamped on the back. Manufactured using the same methods and materials as the original screen used clamp. Does not include a bubble strip.
  • Includes an 8-32 Set Screw, Graflex Eye Screw (In smoke or clear, selectable from the drop down above), and Graflex Red Button Screw.
  • Includes a vented and non-vented pommel insert. Compatible with any MHSv1 MPS Insert. Includes the CClip. If you want us to install either of the included pommel inserts prior to shipping, please let us know via an Order note!
  • Includes Short Graflex Pins
  • Utilizes all MHSv1 parts allowing easy customizations or part swaps if desired.
  • Includes installed bunny ears and ring on the blade holder
These are NOT a complete working saber and do not arrive assembled. The kit does not include a blade, LED, sound module, speaker, etc
All MHS parts should have the threads wiped clean and then lightly oiled or greased. We sell some Synthetic Grease for this. Parts that get stuck because no oil/grease was used or that are damaged by the user trying to take them apart will not be warrantied.
