MHS LSv2 Empty Hilt Kit
The Blade Holder is designed to be used with a 1" Pixel Hilt Side Adapter which is held in place by 2x 4-40 set screws (Included). The blade holder has 4x 8-32 set screws (Included) that are hidden under the outer shroud. The outer shroud is also left hand threaded so that it will not unthread the rest of the parts when being loosened.
Blade depth with our Short 1" pixel adapter = .7" 1" Short Pixel Hilt Side Adapter
Blade depth with our NPXL 1" pixel adapter = .62" 1" NPXL V3 Hilt Side Adapter
These are NOT a complete working saber and do not arrive assembled. The kit does not include a blade, LED, sound module, speaker, etc
- 1" Blade Emitter includes blade retention holes and screws
- LS Blade Plug included
- Includes a vented and non-vented pommel insert. Compatible with any MHSv1 MPS Insert. If you want us to install either of the included pommel inserts prior to shipping, please let us know via an Order note!
- D-Ring is pre-installed in to the pommel for your convenience
- Utilizes all MHSv1 and MTN parts allowing easy customizations or part swaps if desired.
- A mix of Machined 6061 Aluminum with Machined and Anodized finishes.
