1-3/16" ID O-ring are a perfect fit for the ribbed MHS section.
Inside Diameter 1.171"
Outside Diameter 1.449"
Width .139"
Width .139"
(5)
Average rating 9 out of 10
( based on 5
Perfect for the korbanth DM1
I bought 4 of these for the darth maul korbanth hilt and they fit perfectly and look great. Highly recommended them.
Great grips
Easy to roll on. Fit snug. No slip
Does what an O-ring should
It is rubber, round, and has a snug fit on a saber hilt that won't budge when using it. Improved my grip quite a bit for more control and helped my saber to not look like a silver tube. Make sure you order enough. I guessed when ordering as my saber wasn't present and I misjudged.
Sleeve Troubles
My original design consisted of the O-Rings and a MHS sleeve to go over the inner-hilt. Unfortunatly the sleeve won't slide on over the O-Rings, forcing me to have to take them off. After custom cutting the sleeve, there may be a way to stretch the sleeve to fit over the rings, but that is yet to be seen. Othere than that, the rings look great on a ribbed extention.
Perfect for MHS Parts
I used these to add texture to my MHS hilt. I put 8 of them on the Main Body Style 2 and they stay with no problems. I can duel/spin/etc and they stay put. Make sure to use care when putting them on, because these suckers are tight.
