3/4" D-Ring With Short Clip
Mounting tab dimensions
.64" wide
.804" long
.066" tall on the flat
.229" tall where it goes over the ring
.64" wide
.804" long
(5)
Average rating 9 out of 10
( based on 5
Perfect size, rattles a bit.
Fits neatly in the centre of an MPSv1 style 4 or MPSv2 style 3 pommel insert, a 10-32 screw fits it perfectly. The D-ring moves freely and rattles a lot, but a short length of 2mm silicone hose fits easily into the gap and stops it rattling without making it difficult to move.
Great shiny D-ring
This D-ring does it's job great, but I find it to be much better if you roll a bit of tape and stuff it in the empty space where the ring attaches to the mount, so it quiets the 'jingle'. Also, I have to say that the picture is not too accurate because it shows the ring and the mount to be very plain, but it is really like a nickel finish shine, very beautiful. I was going to tap and drill mine, but I ended up just putting it under my retention thumbscrew with a small spring also under the mount, and that makes it hardly move and is almost completely quiet. And just a side note, if you are planning on wearing your saber, with the blade in, I recommend not mounting this to the pommel, unless you are very tall or have a short blade, as the tip of the blade will drag on the ground.
Nice addition. A bit loud.
I am using this on insert style 7. I put this in the center of the insert. I used a 4-40 tap and used a 4-40 button head (not one from here, but some red anodized ones I bought elsewhere years ago). The button head fills the hole in the ring. However you have to center the ring so the button head is centered. I then used a 4-40 lock nut to secure it. Trying to figure out how to quiet the D-ring.
D-ring
Very good product... I tapped mine and adden a nut to be safe, good size best secured in middle of pommel insert, hangs well *****
excelent
