MHS to 1.25" sink tube adapter.
( based on 2
Great for what it is
Works excellent with 22ga 1.25 sink tube. Used these on a pair as gifts for relatives. You can hide the transition area well with properly placed O-rings. Good idea for using sink tube as a body purposefully, but if you are using sink tube as a low cost alternative, you would be better suited to just use an MHS body instead. Not enough cost savings buying this and a sink tube vs. buying a standard MHS body to warrant doing so unless you factor in an MHS pommel.
The ultimate sink tube add on....
Nice piece, gives a sink tube saber a whole new look. Just to point out if you are going to use one of these with a pommel, most battery holders will not fit through due to the small inner diameter, which is 1 inch by the way.
