MTN Blade Holder Style 3
Designed to be used with a 1" Pixel Hilt Side Adapter which is held in place by 2x 4-40 set screws (Included). The blade holder has 4x 8-32 set screws (Included) hidden under the outer shroud.
The outer shroud is left hand threaded so that it will not unthread the rest of the parts when being loosened. When tightening it hold onto the blade to help snug it down without unscrewing the rest of the saber parts.
Blade depth with our Short 1" pixel adapter = .95" 1" Short Pixel Hilt Side Adapter
Blade depth with our NPXL 1" pixel adapter = .87" 1" NPXL V3 Hilt Side Adapter
Will screw onto any female MTN part.
Great for dueling or spinning.
This is great as a stunt blade holder. I use it for both obi and Luke style hilts. I only wish it were possible to buy the outside piece, after building the hilt the inner part is attached and cannot be swapped.
