MHS speaker mount V4
These are designed to be used with the MHS chassis parts we sell.
They are 1.24" OD x .75" long and will slide into most MHS parts.
The 4 holes are 4-40 threaded.
Can be used with the Premium or 2W bass speaker.
(4)
Average rating 9 out of 10
( based on 4
Sturdy
A good chassis part. Definitely fits inside of newer runs of Pommel 10. Definitely be sure that your speaker works before inserting it into the holder, though. It is very difficult to get back out once it's in, so check your circuit beforehand. Barring that, 5/5
Excellent mount
I had no problems with the 2W bass speaker. I ran the battery behind the speaker and filed out slots in the edges for the wires to the battery to run through and still zero issues. For the 4 star comment regarding not fitting a pommel, these are not mean to go inside a pommel. They butt up against the threaded end of the pommel. I had plenty of room for wiring with the 2w bass fully seated inside the mount myself.
Doesn't fit pommel.
I'm sure this must work with certain pommels, but it will not fit inside MHS Pommel #10. I assumed it woukd fit inside an MHS pommel unless otherwise specified. Bad idea. Be sure to measure before ordering.
Great holder a bit too tight though.
Great new speaker holder. It needs to be a bit bigger on the ID though. I have a TCSS 2w speaker and a 2w from Plecter Labs. Neither speaker fits without sanding the black plastic speaker housing. I'd also prefer no holes on the back for custom MHS chassis. Overall another great product.
