Chassis Disc style 4
Designed to screw into a female threaded section so that the chassis can be held in place even if the male section is removed. This will only work with male sections that have .4" long male threads.
Includes 4-40 threaded holes on the outer ring that will match up to both the metal and acylic discs.
Average rating 9 out of 10
( based on 2
perfect fit - no problem
I had no trouble getting this disk in my saber hilt. I just put it on the thread, put a golf tee in one of the holes, and turned the disk until it was at the base of the thread. I made sure to put lubricant on it first. It is a solid fit. The choke and pommel fit on the hilt the same as before--not problem with fit there either.
Great item
This Disk takes some persuasion to get inside your saber. (i had to use a pair of scissors and i had to jam them in the middle then twist it down. Overall a great item don't walk away form this item if you are getting a chassis.
