Acrylic Chassis Disc for a recharge port
Made out of 3/16" acrylic and available in four colors.
Comes with two discs and the center piece for holding a recharge port in your chassis. Use with 1/2" spacers between the discs as shown in the above images.
(4)
Average rating 8 out of 10
( based on 4
Recharge discs
Very well made, strong, fits perfectly, amazing work.
Very convenient/very brittle
These are a very good idea, but they do break rather easily. I recommend a few passes with a piece of fine sand paper or a thin file before assembling. Do a little bit at a time so that the pieces will fit snugly, but aren't so tight that assembly will cause the sides to shatter.
It works, but broke
I received this this morning and immediately went to assemble it into a saber. putting these three pieces together immediately broke one of the sides. The tabs on the middle piece provided too much force to put into the slots. Using glue and the spacers it still holds the recharge port, but it shouldn't have broken.
Works awesome!
I have used this in two sabers and it works great!
