3D Chassis 21700 Battery Holder. Can accommodate either wired or button top. Positive and Negative terminals are included with each chassis but not installed as they can be hard to remove for soldering. Be sure to install the flat terminal on the end with a recess.
Designed to slip on and over 4-40 all threads supporting the chassis (Pictured for example only). Compatible with the MCS Acrylic Discs and Metal chassis discs.
Has a cutout for easy battery removal.
3.42" Tall
OD 1.24"
SLS 3d printed in Nylon 6 or 12 and can be easily Dyed using RIT dye.
Speaker mount, recharge port, battery, and threaded rods are not included and only shown for display purposes
3.42" Tall
OD 1.24"
A+ Quality that TCSS in known for!
Fit and finish are excellent. It is also very well designed (love the battery "ejector"!!!). Love these.
