Adds 2" to length of saber and has 1.7" max OD.
Designed to hold 1" blades.
(7)
( based on 7
Perfect
Amazing emitter! The quality is top notch. Just remember it has a thick wall take that into consideration when getting a blade retention screw. If you are new to the hobby I would suggest getting TCSS to do it for you. I had no problem doing it on my small drill press. As always May the force be with you
Really great blade holder
Really looks great on any saber and I love it on my saber. Can’t say anything else good on it. Just really awesome.
Great Product
This was my second choice for an emitter and i wish that i had started off with this. nice and solid, great threads, really gives the saber the finished look that . you're looking for.
Elegant and able
This emitter is clearly from a more civilized age. The heavier flare at the base of the blade holder makes for a brilliant place to grip the saber, and the weight makes it great for spinning and dueling. I highly recommend it.
Great Blade Holder
This item is much more beautiful in person and is a great addition to any saber project. The holder is designed for a 1" blade. Make sure to get it drilled and tapped because it does not come pre-drilled for a blade tension screw and also does not come with a blade tension screw so make sure you get one. Overall, great product.
