Screw on LED/blade holder for screw together hilt system.
This is the new style and requires the new style heat sink. It will not work with the old style heat sinks unless you use the adapter we sell.
This was designed for people to modify but can be used as is.
Machined to hold the 1" Polycarbonate blades sold here.
1.45" OD x 4" long with a 2" blade holder section and a 2" choke section.
Great Piece, but check the Inner Diameter
I was planning on modifying this blank to my needs, but it seems that there's a choke internally, so this part will not work with the "MHSv1 Neopixel adapter." I'll have to do a bit more modification than I was initially planning on. It doesn't mention the choke anywhere on this page, but if you check the cutout in the MHS builder you can see it. So, it's a good product, but just know what you're getting before purchasing.
