Bezel to mount illuminated switches to MHS parts.
These will only fit 16mm AV switches
The threads on switch 18,19,24, or 25 are not long enough to be used with these.
( based on 2
Top notch quality as always!
This small part is going to work perfectly for my project. As always, TCSS delivers another high end product and shipped to me in record time. I can't speak highly enough about this business. A+++ all the way.
Bezels for easier switch installation
I chose not to opt for the service to machine recess my switch hole, and found that the bezel is the perfect solution for having a clean, raised switch. I found that adding an extra bezel on the inside of the hilt makes it much easier to screw the nut on the back of the longer switch, for a more secure fit, without resorting to methods like hot glue.
