Activation box style 1
(3)
Price: $33.00
  • SKUBox1
This box needs to be mounted to a 3" or longer section in order to mount it with the box mounting service.
These are designed to allow for different style tops to be installed and held in place with 2x 2-56 screws.
The PCB cards that we sell will fit the upper cutout but may need a little sanding.
This is designed to be mounted by 2x 4-40 screws .
2" long x .6" tall (from the outside edge) x .8" wide
(3)
Average rating 10 out of 10 ( based on 3 reviews )
Perfect design
Review by Alexander on 3/18/2025
This is the best box available based on the ease of installation factor. The open space inside makes it much more accommodating than other options.
great fit
Review by Dan on 10/2/2012
These little boxes perfectly fit the PLIs offered here. Which will light through some of the cards (barely). With a little sanding, bubble lenses will also fit on here. Though any cover - bubble or circuit card - needs to be glued down.
very nice and adaptable.
Review by arizona on 9/21/2011
i love this because youre not constricted by a collar like its sister part. not only does it give you the flexibility of box location, but with a bit of hand work and a d-ring, you can make a nice approximation of the kobold d-ring.
