Activation box style 2
These are 2.25" long and may not fit without overlapping grooves/flutes in some main hilts
These will not fit a 3" or shorter double female section
These will mount using two of the 6-32 socket head screws we sell.
These are made to hold the following.
1x Any 16mm AV switch
1x 2.1mm recharge port
1x Small momentary switch 20 or 21 found under Switches>Momentary>Other
2.25" long x .245" tall (in the center) x .875" wide
(5)
Average rating 9 out of 10
( based on 5
Great Product
tall enough for the activation switch i chose. lifts the wire prongs out of the way and helps prevent your wires bunch up inside the hilt. great threading for the switches. super easy to line up to drill and tap. i would recommend that you drill out a big space underneath it (rectangle) to allow your plugs and switches to pass through and not bind on the saber hilt. very happy with this part, definitely gave my saber the "pop" it needed.
Awesome box
I bought two of these. I love how they are already tapped for the switches and the screw right one. Makes building fun. I'll buy more to stock up on,
Perfect
Just what I needed for my first saber. My tall switch fits snug as well as the recharge port. The RC port is leveled off (as seen in pic) which gives it more of a sleek profile. I would like a version with the small momentary switch above the LED switch, but I guess that's what the blank version is for ;)
All in one!
I love how you can put all of your buttons just on the one box. But it does get crowded sometimes. And the re-charge port doesn't stand out of the box. I suggest of making a style of the port? But that's my opinion. Either way, its still great!
I like it, but...
I like this one but I wish it was 3 or 4 times as tall. It'd be nice to get the switch and recharge port farther out of the tube.
