Tri Cree Pre-Wired LED & MHS Heatsink Module. Plug and play for the "TCSS Edition" NBV4 Assembly. This version is wired differently to be plug and play with the harness on the NBv4 assembly and not the standard pre wired NBv4.
These are not plug and play with the standard pre-wired NBv4. Please purchase the other version found here https://www.thecustomsabershop.com/GreenGreenWhite-Cree-Star-LED-MHSV1-Heatsink-Module-P1411.aspx
Includes the following parts
- Choice of either the NHS3 or NHS4 heatsink module
- Tri Cree LED
- Tri LED Lens
- Thermal Tape
- JST male connector Blue- White+ 24AWG
- JST female connector Green- 26AWG
- .1ohm 1w resistor
