Tri Cree Pre-Wired LED & MHS Heatsink Module. Plug and play for the Standard Pre-Wired NBV4 using a single Li-ion at 3.7v .
These are not plug and play with the "TCSS" Edition NBv4 assembly due to changes to the harness. You can find a compatible version of this module here https://www.thecustomsabershop.com/BlueBlueWhite-Cree-Star-LED-MHSV1-Heatsink-Module-for-use-with-NBv4-Assembly-P1457.aspx
Includes the following parts
- Choice of either the NHS3 or NHS4 heatsink module
- Tri Cree LED
- Tri LED Lens
- Thermal Tape
- JST male connector Blue- White+ 24AWG
- JST female connector Black- Red+ 24AWG
- .3ohm 1w resistor
