Activation box style 1
This box needs to be mounted to a 3" or longer section in order to mount it with the box mounting service.
These are designed to allow for different style tops to be installed and held in place with 2x 2-56 screws.
The PCB cards that we sell will fit the upper cutout but may need a little sanding.
This is designed to be mounted by 2x 4-40 screws .
2" long x .6" tall (from the outside edge) x .8" wide
( based on 2
great fit
These little boxes perfectly fit the PLIs offered here. Which will light through some of the cards (barely). With a little sanding, bubble lenses will also fit on here. Though any cover - bubble or circuit card - needs to be glued down.
very nice and adaptable.
i love this because youre not constricted by a collar like its sister part. not only does it give you the flexibility of box location, but with a bit of hand work and a d-ring, you can make a nice approximation of the kobold d-ring.
