On some of these the outer not used section can be hard to remove. The easiest way I have found is to peel off the clear plastic side and stick the LED to the exposed adhesive. Next while holding the LED with the thermal tape towards you grab the outer edges and push away from you so that it uses the LED to help rip the outer edges off correctly.
These pre-cut, thermally conductive, electrically isolating, pressure sensitive adhesive pads are precision cut to fit Luxeon I, III and V Star LEDs. Made from Bond-Ply® 100 pressure sensitive adhesive tape, these pre-cut pads makes it easy to fasten Star LEDs directly to a heat sink without the need for screws.
Features
•Excellent thermal impedance - 0.86°C-in2/W (@100 psi)
•Made from a high performance, thermally conductive, pressure sensitive acrylic adhesive tape
•Electrically isolates the LED from the heat sink
•Immediately bonds to the target surface
•Bond strength increases over time when repeatedly exposed to high continuous-use temperatures
•Pre-cut from Bond-Ply® 100 pressure sensitive tape, manufactured by the The Bergquist Company.
Benefits
•Provides an excellent dielectric barrier
•Can be used instead of heat cure or two part adhesives, mechanical fasteners or mounting clips
•Easy to use double-sided, pressure sensitive adhesive tape that bonds immediately
•High bond strength to a variety of surfaces
Features
Benefits
Average rating 9 out of 10
( based on 2
Great Product
works as advertised. recommend you use a box cutter blade or an exacto knife to peel the backing off. set it and forget it.
Does what it says on the packet
Nothing wrong here but it is nonetheless, difficult to apply because of how small it is. It is also difficult to tear it away from the surrounding paper in some cases.
