Custom Tri-Cree LED with modified base
These have a modified base to fit the .88" OD Heatsink modules. Picture does not show the modifications.
Since these are made to order they will add a few days to the order processing time.
Amber Cree Part# XPEBPA-L1-0000-00D01
107 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 3.28v
Blue Cree Part# XPEBBL-L1-0000-00301
45.7 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 3.4v
Green Cree Part# XPEBGR-L1-0000-00F01
122 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 3.7v
Red Cree Part# XPEBRD-L1-0000-00901
80.6 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 2.65v
Red Orange Cree Part# XPEBRO-L1-0000-00D01
Royal Blue Cree Part# XPEBRY-L1-0000-00S01
650mW Minimum Radiant Flux @ 350mA
White Cree Part# XPEBWT-L1-0000-00F51
266 Minimum Luminous Flux @ 1000mA
Forward Voltage @1000mA = 3.15v
Deep Red Cree Part# XPEBPR-L1-0000-00D01
450 Radiant Flux @ 350mA
Forward Voltage @1000mA = 2.42v
Cyan Cree Part# XPEBBL-L1-0000-00301
Average rating 8 out of 10
Had to trim it a bit more
Leds are excellent, but I had to trim a bit more off the pad to get it to fit into the .88 inch heat sink I bought with it. Nothing difficult just trimmed a mm of a couple points with some tin snips.
