Shouldered 1" blade tips with reflective disc for 1" thin walled tubes.
(3)
( based on 3
Even better!
I have bought a bunch of these over the years and the few I have received lately are even bette!! It seems that the newer ones that are being shipped are a new style. The mirror on the tip is just a little bit smaller in diameter!! This allows the blade tip to light up and give a nice finnished loot to the blade when completed!! So as I said. The best has gotten even better!!!!
Good tip!
This blade tip does exactly what it's supposed to do...gives a nice bright upper-half of the blade, while providing a finished look to your saber. I would like to note that using a glue meant for bonding polycarbonate is a must, as your tip will come off without the proper glue.
Tip adhesive
These tips surpass others simply because of the long shoulder design. The best glue to use is a type that is flexible in nature and won't dry and crack. Try to not use super glue or Methol Ethol Ketone. I use E-6000 from Tap plastics. It adheres to plastic really well and doesn't crack the surrounding plastic.
