SPST 12mm Momentary blue ring Illuminated switch with nickel plated brass body.
There is no internal resistor on these so you need to use the correct resistor in order to not fry the LED. The LED has a forward voltage of 3.0V and runs at 20mA..
Average rating 9 out of 10
( based on 2
True blue
I needed a smaller switch for a hilt I acquired. This switch fit perfectly. The blue is really a true blue color. It will not match the Blue/Blue/White Cree XP-E2 CopperNova, which is more of a cyan.
Not bad!
The only con I have to this switch is it's size, but it is plainly stated that it is 12 mm. If you are going for a main saber activation switch, go with the 16 mm... still, the LED is great... nice and bright, and I can't wait to use it!
