1" blade adapter for carbon fiber tubes.
These may fit tight and require sanding of the tube or may fit loose due to the inconsistency of the carbon fiber tubes OD.
1" OD x .54" ID x 1.75" long. These have a 8-32 threaded hole to lock it onto the tubes. The screw is not included.
Multipurpose in the extreme!
Yes, you can use this to hold a carbon fiber tube, very securely, I might add. It also fits 1/2" acrylic rods and tubes perfectly. The smiths did great work on this piece!
